My fuel injectors, all four, are spraying way too much gas and flooding the engine. What can cause this
Tuesday, October 14th, 2008 AT 6:41 AM
MMPRINCE4000
MECHANIC
Check the fuel pressure with a mechanical gauge. Also check the fuel pressure regulator vacuum line, if gas is present, it should be replaced. Make sure the FP return line is not blocked.
