It has been a while, had to be hospitalixed for a bit. Anyways I still have no fire, and have one more question before I start to just parts replace. Is there anyway to test to see if the computer could be the problem. I can jusmp it if I nned to or whatever, but I dont know if there is a way to test the computer without replaceing it, do you? Tomorrow I am going to replace the igniter first, and plugs and plug wires, because the igniter was abviously sending too much juice to them and they have melted a bit, at least deformed. I would like to know if you agree with my steps tomorrow, first igniter plugs and wires, then ignition, then computer. If not, what would be your steps in parts replacement, or can you think of anything else to check. I could not figure how to check for fire on the positive side ignition coil like instructed. I could not even find coil anywhere in my research, only ignition. Is there an ignition coil that I have missed that I could check, or is it part of the ignition. Thanks, have a good day.
Wednesday, September 23rd, 2009 AT 2:07 PM
