1995 Toyota Corolla Needing to fix a problem
26,000 MILES • 4 CYL • 2WD • AUTOMATIC
AUDREY_ROSE20
I need to know what potential problems I am facing with my car. It idles really rough and sounds very loud lately. It's leaking fluid but I cant tell if its motor oil or powersteering fluid. What things should I check out to eliminate all the extra guessing I've been doing?
Nov 20, 2009 at 6:11 AM
KHLOW2008
  • 41,812 POSTS
Hi Audrey_Rose20,
You have passed the guessing to us, lol.
Where noise are concerned, even with a good and clear description of the noise, it would be difficult to pinpioint the cause without the physical vehicle.
The rough idling could be due to low idling speed, a fault in the idling system or clogging of air passages.
Motor oil would be black in color. Power steering fluid would either be clear or red in color.
Nov 23, 2009 at 12:45 AM
