1995 Toyota Corolla misses after warming up
ALFRED11S
  • 1995 TOYOTA COROLLA
  • 6 CYL
  • FWD
  • 28,800 MILES
After warmup the car misses and sputters during acceleration. My mechanic replaced fuel filter, still sputters he checked fuel pressure and it was good/he replaced distributor/coil/module and checked computer/still same thing.I got some advice as to replace the tps or egr valve he could not find anything wrong electrically is this a possible fix of the problem. He also replaced the distributor/coil/module after it showed no problem. Any help would be greatly appreciated in these tough times. Thanks
Friday, February 26th, 2010 AT 11:19 PM
You sure this vehicle is a 6 cylinder, all I got for the Corolla's is 1.6 and 1.8 liter engines. Anyway check and test the throttle position sensor, manifold absolute pressure, intake air temperarure sensor-clean out the EGR valve-to include the fuel pressure with and w/o vacuum
Saturday, February 27th, 2010 AT 3:42 AM
ALFRED11S
Thanks for the info. Yes it is a 4 cylinder. My goof
Saturday, February 27th, 2010 AT 1:16 PM
