1994 Toyota Corolla A/C blowing hot air during summer
DHANDAPANI
  • 1994 TOYOTA COROLLA
  • 4 CYL
  • 238,000 MILES
In normal weather the AC works fine. But when the outside temperature goes beyond 100 degrees then the AC starts blowing hot air. I live in Dallas and can you please the area I need to focus.
Wednesday, July 1st, 2009 AT 4:41 PM
BUDDYCRAIGG
  • 2,262 POSTS
It could be simply low on freon and the expansion valve is freezing up.
Do you have a set of AC gauges to take pressure readings?
Monday, November 19th, 2018 AT 5:25 PM
DHANDAPANI
No. I will purchase that and I will check the pressure readings.
BUDDYCRAIGG
  • 2,262 POSTS
Take your time and look around, you should be able to find a cheap set for about 40 bucks.
That's what I paid for my first set and they lasted 3 summers and countless cars before I replaced them.
So they should be just fine for your occasional use.
