1992 Toyota Corolla 4 cyl Front Wheel Drive Manual
How we know that ECM has failed?
while running for one hour when I put the gear on nutral the engine goes off. Then I crank but for few times it goes off then I push the accelerator a little for it not to go off. Then it becomes normal. I get the problem when engine is hot.
my mechanic can not figure out whats wrong.
SPONSORED LINKS
Monday, November 2nd, 2009 AT 11:03 AM
