Injectors not firing. Fuel pump working and fuel Rail has correct pressure?
225,000 MILES • 4 CYL • FWD • AUTOMATIC
HENDOG1958
Injectors not firing. Fuel pump working and fuel Rail has correct pressure. Fuel filter checked and changed, no contaminates found in fuel. Injectors removed and checked for contaminates, non found. +13 v present at injectors with ignition in run position. Spark present at all plugs indicate that distributor is at least partially working. There are no codes stored on ECU. I understand that the ECU uses a couple of signals to control the Injectors, such as the neutral switch and a starter signal. The igniter (located in the distributor) may also provide a signal to the ECU for Injector control, is this correct? If so how could I check for this problem? And could there be another problem elsewhere? Any help appreciated.
Nov 26, 2008 at 4:44 AM
BMRFIXIT
  • 19,053 POSTS
When key on BLK?ORG wire should have battery power if not check wire and ignition switch it is the same wire that feed the igniter so if you have spark then I would suspect short in the BLK/ORG WIRE. I have also seen the fuel injector short out internally and shut doesn't the injector drivers inside the PCM. This guide can help you test for that.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Please go over this guide and report back.
Nov 26, 2008 at 2:01 PM
