1991 Toyota Corolla Fuel System
JOHN HOWELL
  • 1991 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • MANUAL
  • 113,005 MILES
My corrola has been parked for 4 yrs. It ran fine when parked. I am to the point where I'm triing to start it. I replaced the fuel and fuel filter. I am getting no fuel through the fuel filter. How do I best figure what the problem is before I have to take the fuel tank off?
Sunday, May 3rd, 2009 AT 5:32 PM
Do you hear the fuel pump come on? If not find the check connector in the engine compartment and jumper batt to Fp let me know what happened.
Sunday, May 3rd, 2009 AT 5:40 PM
MMPRINCE4000
  • 8,548 POSTS
Did you add a fuel stabilizer to fuel?
If not then you have probably clogged up the entire fuel system with varnish as the gasoline decomposes, which usually starts within 30-60 days.
As Raz said short B+ and Fp on diagnostic link on left shock tower, if pump does not run, replace it.
Monday, May 4th, 2009 AT 6:24 AM
