1991 Toyota Corolla Can't get fuel to the cylinder
JOHN HOWELL
  • 1991 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • MANUAL
  • 136,002 MILES
Fuel pressure is good to the fuel rail. I took out a spark plug to check the spark. It is getting fire but the plug was very dry with no smell of gas. (Plugs are brand new) I would say that no gas is getting in the cylinder. (Car will run with a squirt of starting fluid but stops when starting fluid is burned up.) I understand that the fuel injectors may be clogged but how do I find out if it is an electrical problem in the injection system or a fuel pressure/delivery problem?
Friday, May 8th, 2009 AT 8:19 PM
Try listening to the injectors with a long screwdriver is it making a clicking noise if not its not snchronizing-check for power to it
Friday, May 8th, 2009 AT 8:51 PM
JOHN HOWELL
  • 8 POSTS
I used the screwdriver to the ear trick on the injectors and heard the audible clicking. That was a new one for me, but worked incredibly well. So is my next step to remove the injectors?
Friday, May 8th, 2009 AT 9:54 PM
Next step is to check the fuel pressure hook up the gauge to the fuel rail and comeback with the pressure readings
Friday, May 8th, 2009 AT 10:13 PM
