1991 Toyota Corolla
HAYLEY10
  • 1991 TOYOTA COROLLA
1991 Toyota Corolla Front Wheel Drive Automatic
HI I JUST WANTED TO KNOW WERE MY FUEL FLOAT WAS IN MY CAR AND IF IT WOULD BE AN EASY THING TO FIX
Wednesday, August 25th, 2010 AT 2:01 AM
  • 31,937 POSTS
Hi there,
Are you referring to a carby fuel float or the fuel tank sender fuel float?
Mark (mhpautos)
Wednesday, August 25th, 2010 AT 4:50 AM
MMPRINCE4000
  • 8,548 POSTS
91 Corolla's are FI, no carbs. There is a float for fuel gauge in tank, you have to remove tank to get to it.
Find a replacement before you do.
Wednesday, August 25th, 2010 AT 8:04 AM
  • 31,937 POSTS
G'Day MM,
Here in Aust we still had a carby version of the corolla in 91, that is why I asked that question,
mark (mhpautos)
Wednesday, August 25th, 2010 AT 4:43 PM
MMPRINCE4000
  • 8,548 POSTS
Thanks for the info Mark.
I assumed (:) ) he was talking about U.S. Corolla.
Thursday, August 26th, 2010 AT 8:31 AM
HAYLEY10
Hi
its the fuel sender float that I need to know about coz mine dosent work and im not sure wat I need to do to fix it
Friday, August 27th, 2010 AT 5:56 AM
  • 31,937 POSTS
You will have to remove thew fuel tank to access the sender unit, you will have to remove thew screws and with draw the sender/fuel pump assembly from the tank.
Mark (mhpautos)
Friday, August 27th, 2010 AT 6:18 AM
MMPRINCE4000
  • 8,548 POSTS
Just make sure you can find a replacement before you do it.
Friday, August 27th, 2010 AT 8:17 AM
HAYLEY10
I was told to remove a wire off my fuel sender unit then earth it out and if it goes to full its my sender and if it goes to empty its my guage and I was just wandering if this is right
Saturday, August 28th, 2010 AT 5:43 AM
MMPRINCE4000
  • 8,548 POSTS
One wire is a ground (earth) the other is the sender wire to gauge.
If you ground the sender wire, gauge should go to empty, or close to it.
The sender sends a resistance number in ohms to the gauge, for example 0 ohms would be empty, 90 ohms would be full.
The problem would be finding a replacement, if Toyota has one, it is most likely not cheap.
Saturday, August 28th, 2010 AT 8:08 AM
Related General Content
