HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
General
1991 Toyota Corolla
JAMES CHIKUNJI
MEMBER
1991 TOYOTA COROLLA
4 CYL
FWD
MANUAL
116,045 MILES
How can I tell that the fan is working because the temperature does not go above but water level goes down in most cases?
Thursday, February 26th, 2009 AT 5:41 AM
MECHANIC
If you're talking about the cooling fan direct power to it from the battery
SPONSORED LINKS
Thursday, February 26th, 2009 AT 5:44 AM
MMPRINCE4000
MECHANIC
You can also disconnect the fan switch connector, a white one wire connector directly under distributor.
With connector disconnected, the fan should run all the time the ign. Is "on". If not the fan motor is suspect and test as Rasmataz instructed.
If fan runs connected directly to battery, replace "engine main" relay.
Thursday, February 26th, 2009 AT 6:47 AM
Please
login
or
register
to post a reply.
Related General Content
GUIDE
Inquire Here
SPONSORED LINKS
Avoiding Car Repair Fraud
Ten Questions to Ask a Repair Shop
Rebuilt or Refurbished?
Online car repair manuals
