1990 Toyota Corolla Left Wheel area makes "clicking&am
JON1JT
  • 1990 TOYOTA COROLLA
  • 4 CYL
  • 170,000 MILES
My car makes a clicking sound in the left wheel area when I turn right, but when I straighten it the clicking goes away. Also, the front inside tires are wearing out. A car mechanic I've never used before believes the clicking is coming from the axle and needs to be replaced.
The mechanic said to have a realignment done preferably the same day the axle is done. He was prepared to make me an appointment to replace the axle without even checking it first. What do you think?
Would getting an alignment done first be worth doing to see if the clicking stops and front tires stop wearing out?
Thanks in advance.
Sunday, November 1st, 2009 AT 10:33 PM
Could be the boot or the CV joint itself on the axle-
Would getting an alignment done first be worth doing to see if the clicking stops and front tires stop wearing out? Get the alignment and replace what's defective.
Monday, November 2nd, 2009 AT 12:23 AM
MMPRINCE4000
  • 8,548 POSTS
If outer tie rod was removed, you must get car aligned, when CV axle is changed, Outer tie rod affects alignment "toe".
Monday, November 2nd, 2009 AT 8:01 AM
