1990 Toyota Corolla e10 on my corolla 1990
GMEIGHT
1990 Toyota Corolla
hi! just have a question regarding what gas will I use for my car. I heard that e10 fuel can damage my car? is that true? currently most of the fuel being sold here has e10. So far Im using petron blaze which has no e10 yet. is blaze better that other premium gas?Any advise on what fuel to use for my car? Thanks!
Apr 18, 2010 at 9:53 PM
  • 31,937 POSTS
Hi there,
E10 will be fine for your car, and foe added protection i suggest that you use an upper cylinder lube additive with each tank full of fuel, something like flash lube ore any over the counter additive will be fine.
mark (mhpautos)
Apr 18, 2010 at 10:31 PM
MMPRINCE4000
  • 8,548 POSTS
To add to Mark's great advice:
It is Methanol you want to avoid, at ANY level.
Almost all cars from the mid-eighties on can run on E-10. Expect slightly lower mileage.
Apr 19, 2010 at 1:56 AM
GMEIGHT
does this mean e10 is safe to use for carb engines? Will there be any side effects in the furure? Thanks a Lot!
Apr 20, 2010 at 4:33 AM
  • 31,937 POSTS
Hi there,
The E10 will be ok in the carby with no long term problems expected.
mark (mhpautos)
Apr 20, 2010 at 11:53 AM
