Inspect the waterpump for leaks, especially at the weep hole, if you see any coolant, replace the pump.
Make sure the cooling fan is working, if you turn the AC on the fan should come on, slow speed at first.
If the fan does not come on, disconnect the fan switch connector, the fan should come on and run continously, if it doesn't come on then the fan is bad, wiring to it or a relay/fuse.
If the fans are working and waterpump is OK, then I would replace the thermostat (use a Toyota part).
I would also purchase a Haynes manual for your car, it will give you procedures for diagnosing problems as well as repair procedures.
SPONSORED LINKS
Monday, May 5th, 2008 AT 7:33 AM
