1988 Toyota Corolla pin locations
1988 TOYOTA COROLLA
TRACKFODDER
Computer problem
1988 Toyota Corolla 4 cyl Front Wheel Drive Manual
I am building a car using a 4A-GE from a GT-S and only have the engine loom. There is another socket that as I understand only has to be connected to ground and power. I need the pin locations. Also there is a spade plug around the corner from the 3 sockets I need to know the function of. All I want to do is run the injectors and spark, and possibly shut off the fuel pump in a wreck. In other words I need the engine to function. Keith Williams
Jan 19, 2009 at 4:44 PM
MMPRINCE4000
  • 8,548 POSTS
Was the 88 original engine carb, or FI? If carb you will have to change fuel pump. The 4AGE was offered in the 88, so it depends on what engine was originally in the 88. The 4AFE, 4ALC, or 4AGE
I would get a factory manual for the 4AGE engine, a 1988 manual. It will give you the wiring diagrams you need to complete the swap.
Jan 19, 2009 at 11:07 PM
