1985 Toyota Corolla engine starts but shuts off
BORICUA1975
  • 1985 TOYOTA COROLLA
Engine Performance problem
1985 Toyota Corolla 4 cyl Two Wheel Drive Manual
Have a 1985 Toyota corolla 4age. Car starts for 4 seconds bit then shuts off. I have checked timing, spark, replaced fuel pump, checked for vacuum leaks also replaced the air flow sensor. Don't know what else to check.
Tuesday, September 28th, 2010 AT 9:41 PM
Check the Auxiliary Air Valve (Idle Speed), EGR and PCV valves and recheck the fuel pressure.
Also check the choke opening and fast idle cam adjustment- A/F mix and curb idle speed adjustment
Wednesday, September 29th, 2010 AT 5:37 AM
BORICUA1975
  • 11 POSTS
I have tried everything but fuel pressure, checked manual, what's Max Psi.
Wednesday, September 29th, 2010 AT 11:52 AM
EFI fuel system-33-38psi
Carb fuel system 3-5psi
Wednesday, September 29th, 2010 AT 12:03 PM
BORICUA1975
  • 11 POSTS
Just noticed the idling stabilizer amplifier is missing, would that affect the ecu.
Wednesday, September 29th, 2010 AT 1:37 PM
