1984 Toyota Corolla CAR BREAKS
OBI
  • 1984 TOYOTA COROLLA
Brakes problem
1984 Toyota Corolla Engine Size unknown Two Wheel Drive Manual 650000 miles
Car breaks not holding after drive shaft bearing and reak shoes changes were made (Toyota Corolla KE70)
Thursday, March 6th, 2008 AT 1:50 PM
MASTERTECHTIM
  • 4,750 POSTS
Is there brake fluid leaking?
Thursday, March 6th, 2008 AT 1:57 PM
OBI
I've ckecked the brake lines and did not notice any leakage.
Friday, March 7th, 2008 AT 5:11 PM
MASTERTECHTIM
  • 4,750 POSTS
I would first bleed all 4 wheels to see if air somehow got in there
Friday, March 7th, 2008 AT 5:16 PM
OBI
Thanks, I will do just that as soon as I can get my mate to help me pump the brake padles while I bleed the brakes.
Friday, March 7th, 2008 AT 5:20 PM
OBI
I had to change the Master Cylinder due to a slow leakage. I bleed all four brakes as you suggested and the brakes are OK, though a little bit soft. I may have to bleed them again to get the correct resisitance from the brake padale. Right now it is going all the way to the floor.
Thanks
Tuesday, March 11th, 2008 AT 2:25 PM
