HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Drivetrain
Transfer Case
Wiring
SPONSORED LINKS
1980 Toyota Corolla
CHARLITO1986
MEMBER
1980 TOYOTA COROLLA
Electrical problem
1980 Toyota Corolla 4 cyl Front Wheel Drive Automatic
how can I find electrical wiring system cause the hole car needs wiring from front to back
Wednesday, August 19th, 2009 AT 1:57 PM
MMPRINCE4000
MECHANIC
Use car repair link in this thread, or try to find a factory manual on ebay.
On an almost 30 year old car, it will be hard to find.
SPONSORED LINKS
Thursday, August 20th, 2009 AT 8:38 AM
MECHANIC
Hi there,
I often find older manuals I need for restoration work line, just do a search for used car repair manuals, you should find what you want.
Mark (mhpautos)
Thursday, August 20th, 2009 AT 8:35 PM
Please
login
or
register
to post a reply.
Related Transfer Case Wiring Content
1995 Toyota Corolla Smell Oil
Smells Problem 1995 Toyota Corolla 4 Cyl Front Wheel Drive Automatic My Car Is Not Leaking Or Smoking But I Smell Oil When I Drive...
Asked by
msmarti
1995
TOYOTA COROLLA
1990 Toyota Corolla Gear Change
Transmission Problem 1990 Toyota Corolla 4 Cyl Two Wheel Drive Automatic 150 00 Miles I Have Had My Carolla For A Year Now, Went...
Asked by
prasheel
1 ANSWER
1990
TOYOTA COROLLA
Have A Toyota 93 1.8 Manual ,tests Done And Found...
Cyl 1 -150psi Cyl 2 -150psi Cyl 3 -150psi Cyl 4 - 85psi What Does This Mean And Is This Is What Makes The Car Idle Rough. What Can I Do...
Asked by
Angieee
1993
TOYOTA COROLLA
1995 Toyota Corolla
Engine Performance Problem 1995 Toyota Corolla 4 Cyl Two Wheel Drive Automatic Hi When I Start My Car In The Morning, Sometimes The...
Asked by
kamboo
1 ANSWER
1995
TOYOTA COROLLA
1989 Toyota Corolla
Engine Mechanical Problem 1989 Toyota Corolla 4 Cyl Two Wheel Drive Automatic How To Remove And Install A Engine In A 1989 Toyota...
Asked by
autoshopsecrets.com
1 ANSWER
1989
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Driveshaft Removal
Service a Transmission Ford F-150
Transmission Mount Replacement - RWD Cars
Online car repair manuals
