1994 Toyota Celica Coolant Leak
SDAGGAN
I have a 1994 toyota celica, and it started leaking coolant on the floor of the passenger side of the car. I took it to a mechanic who said it was the heater core and that it would cost over $1,000 to replace it. I was wondering if this is an outrageous price for replacement, or if there was some kind of solvent I could use that might temporarily seal the heater core.
Jul 2, 2007 at 8:22 AM
  • 75,988 POSTS
[quote:9428c83cdf="sdaggan"]I have a 1994 toyota celica, and it started leaking coolant on the floor of the passenger side of the car. I took it to a mechanic who said it was the heater core and that it would cost over $1,000 to replace it. I was wondering if this is an outrageous price for replacement, or if there was some kind of solvent I could use that might temporarily seal the heater core.[/quote:9428c83cdf]
Better check the drain tube might be the one that causing the backflow in the pax side. Did he tear it apart to confirm its leaking from the core.
What K-too much,get a 2nd quote or whatever.
Jul 16, 2007 at 11:50 PM
Suggested Repair
Check the HVAC drain tube for blockage or backflow before replacing the heater core, and confirm the mechanic actually verified the leak source. Get a second quote, as a repair over $1,000 may be high.
Conversation Summary
The owner of a 1994 Toyota Celica reported coolant leaking onto the passenger-side floor. A mechanic diagnosed a heater core and quoted over $1,000, and the owner asked whether that price was excessive or if a sealant could temporarily stop the leak. The expert advised checking the drain tube for backflow, confirming the core was actually opened and verified as the leak source, and getting a second quote.
