1990 Toyota Celica Gear Grind
[color=red:7816028cf7][/color:7816028cf7]Hi! My clutch has cable system and the freeplay seems to be fine but the thing is that while realeasing the cluth it catches all the way up but to switch the gear it has to be pressed all the way to the bottom. Does it matter or is that fine?
Suggested Repair
Confirm about 1/2 inch of clutch free play. A high release point and the need to press the pedal fully to shift indicate wear of the clutch disc and clutch cover, so plan to replace them. If adjustment and clutch replacement do not stop the grinding, inspect the transmission internally.
Conversation Summary
A 1990 Toyota Celica GT manual grinds in second and third only above about 3000 RPM. A fluid change helped briefly, and the clutch was described as new with a previously rebuilt transmission. The expert advised checking clutch free play and, on a hydraulic system, pumping the pedal; otherwise an internal transmission fault was possible. The owner reported a cable clutch with acceptable free play, but engagement only near the top of pedal travel and the need to fully depress the pedal to shift. The expert said that pattern indicates wear of the clutch disc and cover and will worsen over time.
