Electrical Problems for a 1994 Toyota Celica w/ 125,000
1994 TOYOTA CELICA
HARMANL
I have a 1994 Toyota Celica that I recently needed to jumpstart. However, I made a mistake and accidentally switched the jumper cables. They weren't on for long, but I think the damage was done as I can't get the car to start. However, I think something is wrong with the electrical system. What else might I have fried? Before I connected the batteries, my power locks worked fine, afterwards I couldn't even lock the doors or get something as small as the clock to turn on. The fuses all appear intact, so what else may be wrong?
Feb 11, 2007 at 7:59 AM
STRATUS98
  • 96 POSTS
is your check engine light on?
Feb 11, 2007 at 8:08 AM
HARMANL
No, however I did notice that the open door symbol on my instrument panel does light up. That was the only evidence of electrical activity I could see. The radio doesn't work, the clock doesn't work, the chime doesn't work, the locks don't work, and the windows don't work. And the car definitely won't start.
Feb 11, 2007 at 8:17 AM
STRATUS98
  • 96 POSTS
I am not 100% on this but I think you fried your ECU. You may replace it, just to find you still of some problems, in which case I would think the BCM shorted to. I am sorry I couldn't help you more and I hope someone else will chime in
Feb 11, 2007 at 12:56 PM
