1991 Toyota Celica car wont shift
1991 TOYOTA CELICA
189,000 MILES • 4 CYL • FWD • AUTOMATIC
CANDYAPPLES91
My celica has a reman tranny and was working fine until the other day. I let it warm up and went to drive and it wouldnt shift out of 1st gear. The tranny fluid was about a qt over so I drained it until the levels were correct, fluid is proper color and smells as it should. Could the fact there was too much fluid send the computer into limp mode or is my problem bigger? How can I rectify this?
May 21, 2008 at 5:13 AM
  • 31,937 POSTS
Hi there,
the trans being a little over full will not be a problem. I would do a scan to see if there's a fault code, but i feel you will need to visit a trans specialist as this my be an internal issue.
Mark (mhpautos)
May 21, 2008 at 6:51 PM
CANDYAPPLES91
Hey thanks actually yesterday I ran into a neighbor who said something was stuck open/shut and while driving tacked it to 6 or 7 then dropped it into 2nd and back up, he repeated the process twice and now the car shifts fine. I'm still getting it checked out but I thought this info might make sense as to the problem. Why did this work?
May 22, 2008 at 5:48 AM
