When I am driving the transmission makes a noise like something is rubbing up against something. The noise seems to get louder when you make sweeping left turns. I put the car on jackstands and got under it, it seems like ware the axels go into the differental is loose. Also when the car is in neutral and you rev the motor passed 2000rpm there is a very noticeable vibration. But it seems to go away when you put it in gear. And it also shifts into overdrive really early. Thanks for looking it over.
SPONSORED LINKS
Monday, December 24th, 2007 AT 4:24 PM
