1989 Toyota Celica
RACE2419
  • 1989 TOYOTA CELICA
1989 Toyota Celica 4 cyl Manual
I have an 89 toyota celica and I no longer have the key. The steering wheel is locked and I cannot steer the car. I was wondering how to bypass this problem without getting a new key.
Tuesday, August 11th, 2009 AT 6:47 PM
  • 31,937 POSTS
Hi there,
the steering lock and ignition key assembly are all part of the same mechanism, the ignition switch is attached to the rear of this, you will have to remove the steering wheel and trims, the lock it fitted with tamper proof bolts that will have to be drilled out to remove the lock.
Mark (mhpautos)
Wednesday, August 12th, 2009 AT 12:32 AM
