1988 Toyota Celica Voltage gauge on dashboard
88,000 MILES • 4 CYL • FWD • MANUAL
DHALEY
I recently got a new battery and a new alternator, after a few days, the voltage gauge (i think its called) the needle fluctuates while driving, which it never did before, what does that mean, I do not want to be left by the side of the road again in this car because of a medical condition.
Sep 14, 2010 at 5:28 AM
DSPLC
  • 220 POSTS
I read this article to explain about voltmeter. If it is not performing within the specs., get your alternator and voltage regulator check. Most alternators sold at Auto Parts store are remanufactured / rebuilt, not new. A fully charged battery will read about 12.5 volts when the engine is not running. When the engine is running, the charging system takes over so that the voltmeter will read 14 to 14.5 volts and should stay there unless there is a heavy load on the electrical system such as wipers, lights, heater and rear defogger all operating together while the engine is idling at which time the voltage may drop. If the voltage drops below 12.5, it means that the battery is providing some of the current. You may notice that your dash lights dim at this point. If this happens for an extended period, the battery will run down and may not have enough of a charge to start the car after shutting it off. This should never happen with a healthy charging system because as soon as you step on the gas, the charging system will recharge the battery. If the voltage is constantly below 14 volts, you should have the system checked. If the voltage ever goes above 15 volts, there is a problem with the voltage regulator. Have the system checked as soon as possible as this "overcharging" condition can cause damage to your electrical system.
https://images.2carpros.com/forum/automotive_pictures/89255_voltmeter_1.gif
Sep 15, 2010 at 11:10 AM
