My car will crank but not start due to lack of fuel. I suspect the fuel pump so I removed the power connector and used a voltmeter. The voltage varies from 0-10Volts and fluctuates very regularly every second.
Is this the correct form of voltage that should be present ?
Thanks
Thanks
Nov 5, 2008 at 3:50 PM
