1996 Toyota Carib PO773 code
1996 TOYOTA CARIB
96 CAMRY
Transmission problem
1996 Toyota Carib 4 cyl Front Wheel Drive Automatic
The car has no symptoms other than the check engine light and remaining last wk. Had car diagnosed by auto-zone and a certified mechanic. Took car to a transmission shop as the code said shift solenoid electric.
The solenoid and wiring/filter/fluid was replaced, this past Tuesday.
The code was cleared.
Since then, everytime the car sits for more than 9 hours, the CEL light comes/stays on again. Took car back to transmission shop 2 days ago, they found nothing. Code cleared again. Next morning after driving for 2 miles and restarting, CEL back on again.
This morning took car to auto-zone for a scan..same code comes up PO773.
Some say to drive car and eventually the computer will read repair has been done. Auto-zone says maybe the solenoid that was replaced was bad.
Will call transmission shop again tomorrow (warranty 90 days).
Any ideas why this CEL and code returns?
absolutely no symptoms with the car, it runs beautifully..other than the CEL light on.
Nov 8, 2009 at 5:31 AM
  • 31,937 POSTS
Hi there,
You may well have a faulty solinoid, but it is important to understand that the problem may be in the wiring or the ecu, more often than not the problem will be a solinoid, but you should be checking all possibilities, especially as you are still experiencing the same code popping up.
mark (mhpautos)
Nov 8, 2009 at 9:34 AM
