Rear window defroster
TOYOTA CAMRY
WAYNEG
1993 Camry 4 door. The light on the rear window defroster switch lights when the switch is on, but the defroster does not work. Car was rear-ended and has a new rear window. I can't tell how/where the wiring attaches to the defroster. Suspect the defroster was not properly connected when replacement window was installed.
Jan 13, 2006 at 8:13 PM
2CARPRO JACK
  • CERTIFIED EXPERT
  • 11,533 POSTS
should be a small connector near the edge of the rear window
Feb 10, 2006 at 2:31 PM
