1993 Toyota Camry Power Surge
MYCHEM23
Hey all. ok im going to do my best in describing my problem in hopes that someone out there can help me in fixing my car issue. i have a 93 v6 camry. ok so every once in a while my car will power surge and sometimes hesitate. it doesnt happen all the time maybe like once a week but anyways it only does it when you first start to accelerate. today my husband was messing around with it and just tapping on the gas pedal and letting up really quick and it would power surge and act up. also every once in a while it will idle low at about 500- 600. now other than that the car runs great. we do need a new o2 sensor so im not sure if that could be causing the power surging or not. we live on a very limited income and this is our only car so im desprate to get the problem fixed before it gets to big. also is it a possibility that the timing belt or accessory drive belt could be doing this? the only reason i ask about those two parts is we recently took it in for an oil change and they told us we needed to get those replaced. anyways help me !!!!!!!
thanks
-sara
Feb 20, 2007 at 6:54 AM
  • 75,988 POSTS
Lets do the O2 sensor 1st its way over due The O2 tells the computer how much fuel is needed in a given operational condtions. In other words fuel demand
Feb 20, 2007 at 6:10 PM
Suggested Repair
Replace the overdue oxygen sensor first. It tells the computer how much fuel is needed under different operating conditions and may be causing the intermittent surge, hesitation, and low idle.
Conversation Summary
A 1993 Toyota Camry V6 intermittently surges or hesitates when first accelerating and sometimes idles around 500-600 rpm, but otherwise runs well. The owner needs an oxygen sensor and asked whether the timing belt or accessory drive belt could cause the issue. The expert recommended replacing the overdue oxygen sensor first because it controls fuel delivery based on operating conditions.
