I have a 91 Camry. I had the same problem. One by one, pull the spark plug wire from each spark plug. Check the ends of wires (the tips that connect to the plug) for oil on them. If any or all of them have oil on them, it means your valve cover gasket is leaking oil, which is collecting at the bottom of the spark plug tube causing your spark plug wires to intermittently short out. I took my car to a mechanic who fixed it for me. I believe this is a common problem on old Camry's from like 89-91. You could probably fix it yourself if you have time, experience and faith in yourself. If you haven't had a tune-up and oil change in a while, it would be good to get one.
Another time, I also had funny problems where it felt like my car was missing but I traced it too the alternator (because eventually the headlights and dash did begin to finally dim). The bearings in the first alternator I got wore out withing a few thousand miles, so I took it back and got a new one and have been fine since.
My car, under full acceleration still sometimes feels kind of funny. I think that's because of nearly 200,000 miles so probably some slight loss of compression among other things.
Dec 26, 2006 at 2:56 PM
