Camry hesitates
CAMRY_Q
I have a 2000 Toyota Camry LE V6 with 115,000 miles. It's an automatic, 2 wheel drive. Lately, whenever I run the air conditioning, the car hesitates. When accelerating from a stop the engine chugs until I pick up speed, and at around 45 mph, you feel the same hesitation/chugging. At other speeds, the hesitation isn't noticeable. When the A/C is off, there is still some hesitation, but not as bad as when the A/C is on. I had the car tune-up at 60K miles and I've had the fuel injectors cleaned recently. I also changed the air filter last week, but the problem continues.
Thanks for your help!!
Aug 20, 2007 at 10:48 PM
  • 75,988 POSTS
[quote:498aec4825="camry_q"]I have a 2000 Toyota Camry LE V6 with 115,000 miles. It's an automatic, 2 wheel drive. Lately, whenever I run the air conditioning, the car hesitates. When accelerating from a stop the engine chugs until I pick up speed, and at around 45 mph, you feel the same hesitation/chugging. At other speeds, the hesitation isn't noticeable. When the A/C is off, there is still some hesitation, but not as bad as when the A/C is on. I had the car tune-up at 60K miles and I've had the fuel injectors cleaned recently. I also changed the air filter last week, but the problem continues.
Thanks for your help!![/quote:498aec4825]
I would say it needs another tune-up
Aug 20, 2007 at 10:58 PM
BURTONAB
Did you ever figure this out? My car is doing the same thing now. Thanks.
Sep 21, 2012 at 10:56 AM
