brake lights.....refuse to go off
TOYOTA CAMRY
BLK BUTTAH
hello everyone lst time poster here,have a 1999 toyota camry and my brake light will not go off,ive tried to play with the emergency brakes..ie..*up and down*...no luck :cry: ..i had to disconnect the battery just to get it to go off,someone says it may be my harness is stuck can anyone advise me how to fix this on my own?
Jan 27, 2006 at 11:10 AM
HITEK
  • 30 POSTS
Check the switch[ upper the brake peddle].
Jan 29, 2006 at 1:18 AM
GREASEMUNKE
  • 35 POSTS
Hitek is right.Get down and look at the upper part of your brake pedal.When the pedal is pressed your switch circuit is closed which cause your brake lights to come on.If this switch gets stuck that would keep your brake lights on.It is the only electrical thing on the top part of your brake pedal arm
Jan 30, 2006 at 12:12 AM
