1994 Toyota Camry Alarm Keeps Going Off
RFLACKEY
How do I disconnect the alarm system from a 1994 Toyota Camry? I replaced the battery and now the alarm continues to go off. My remote no longer works for me to turn it off that way so I would like to simply disconnect the alarm system so my car will start. Thank you!!
Mar 11, 2006 at 3:16 PM
  • 75,988 POSTS
Find the Auto Theft Deterrent then cut the Red wire, it should be left from the steering column
If you decide to unplug it your car will not start.
Mar 20, 2006 at 11:11 AM
Suggested Repair
Locate the auto theft deterrent left of the steering column and cut the red wire. Do not simply unplug the unit, because the car will not start.
Conversation Summary
The owner of a 1994 Toyota Camry replaced the battery, after which the alarm kept sounding and the remote no longer shut it off. They wanted to disconnect the alarm so the car would start. The expert advised finding the auto theft deterrent left of the steering column and cutting the red wire, and warned that unplugging the unit will prevent the car from starting.
