93 Toyota Camry Transmission
1993 TOYOTA CAMRY
ALEXANDER
How do you know if your transmission is going or if you just need to replace the fuel filter. I just started noticing problems on the 14th.
The car run normal and then will slow down and then speed back up. It seems as though it is not getting fuel, but then sometimes when it's in park and then you put in Drive it jerks, but not all the time.
Going up a hill I lose speed at times and then it catches. Any suggestions?
Jan 17, 2006 at 4:39 AM
CHRISYANG
I think your trnsmission is going to go out on you. Same thing happen to my mom's car, had to replace the trnny on it.
Jan 19, 2006 at 2:28 PM
