'88 Camry Loose Shifter O/D Light
1988 TOYOTA CAMRY
PASTAHEADRAY
  • 5 POSTS
Re My ‘88 Toyota Camry DX 2L 4Cyl Automatic 220,000 Miles. Another question; the shifter for the automatic transmission is a bit jiggly and loose. I ask this in concert with my next question. The red “O/D Off” dash light is intermittent. (The over drive (4th gear) is actuated by the button on the back of the shifter). Could this be caused by the loose shifter, and is this a cause for concern, the concern being mainly about the loose shifter.
Jul 28, 2007 at 9:37 PM
2CARPRO JACK
  • CERTIFIED EXPERT
  • 11,533 POSTS
If you use the button on the shifter will th e O/D turn on? Might want to take shifter apart to see if any wires are damaged if it wont turn on
Jul 30, 2007 at 8:08 AM
