2005 Toyota Camry ABS light, Check engine light, Brake ligh
SWEETCAROLINE
  • 2005 TOYOTA CAMRY
  • 6 CYL
  • 55,000 MILES
The other day I got into my car and as I started the engine I noticed that the brake light was on, the ABS light, the check engine light - all on. The speedometer wasn't working anymore, also the power-windows weren't working and the fuel gauge was going up and down as it pleased. It went away the next time I got in the car, but reappeared a few days later. Now it's constant and I can't roll down my windows or see how fast I am going or when I'm about to run out of gas. I had all my fuses checked and also was wondering if it might have anything to do with the ignition or the coil? What could it be and how can I fix it? What am I looking at money-wise if I have to take her in?
Tuesday, October 27th, 2009 AT 1:30 AM
MMPRINCE4000
  • 8,548 POSTS
Shops usually charge $80 for a PCM scan to get error codes, depends on what is wrong, but in this case it sounds like a short or open wire.
You may have a wire harness that was burned by an exhaust leak or something close, but reading the codes is the first thing to do.
Tuesday, October 27th, 2009 AT 9:53 AM
