2005 Toyota Camry
GJETLEY
  • 2005 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 43,000 MILES
Had oil and filter and intake filter changed now engine light is on and motor stops running after warming up seems if try to accelerate to fast it dies but then after a bit slightest acc will cause to die if key is turned off engine will start quite easily the key code says r&r throttle body
Friday, March 12th, 2010 AT 5:03 PM
SERVICE WRITER
  • 9,123 POSTS
Take it back to the person that did the work and have them look over their work. If they moved the throttle plate manually, it may have thrown the calibration out. There is also a possiblity of something not being reconnected.
Not sure what you mean by intake filter. Air filter?
Make sure the snorkel was re-installed tightly. Any un-metered air will also cause this kind of reaction.
Saturday, March 13th, 2010 AT 5:18 AM
