2003 Toyota Camry Check Engine Light
NDIRISHFAN1967
  • 2003 TOYOTA CAMRY
  • 4 CYL
  • 81,500 MILES
The Check engine light came on the other day. Took it into the local Toyota dealer. Thye tell me it is a P0420 Converter Below Threshhold error. The converter (catalytic?) Would need to be replace along with 2 gaskets. ~$700.
First, does this sound correct? Second, if I keep driving it, will I do any further harm? Should I be having these issues with only 81K miles? Any info would be appreciated.
Monday, November 24th, 2008 AT 7:23 AM
DSPLC
  • 220 POSTS
My friend got the same year model camry (95,000 miles). Dealer replaced the same thing. Correct: $700 for catalytic converter replacement.
For 81,500 miles, I do not get it either. My 99 Camry got 215,000 miles and still using the original catalytic converter.
You can still drive it but it will not pass smog emission inspection. To reset the check engine light (if you do not have the OBD II scanner). Remove one side of the battery terminal, wait for a minute and put it back on. If around 100 miles, the check engine light came back on, then Toyota dealer is correct. If the check engine light does not come back on. Then your car is okay.
P0420 - catalyst system efficiency below threshold.
Reasons for this reading according to service manual:
1. Catalytic converter
2. Oxygen sensor or air fuel sensor
Wednesday, November 26th, 2008 AT 3:16 PM
