Tried to start my car and I hear is a continuous clicking noise.
COZMIK106
  • 2003 TOYOTA CAMRY
I recently tried to start my car and I hear is a continous clicking noise. It sounds like it wants to crank to start the car, but nothing happens. Everytime I turn the iginition, the continous clicking noise lights up the instrument panel with the same amount of flicker as the noise.
I swapped batteries, but the noise remains the same and the car will not start. I replaced the starter and starter relay (both of which) I think are probably not at fault. Any ideas?
Monday, May 26th, 2008 AT 4:27 PM
Make sure the battery has an open voltage of 12.4volts or better and cleaned/properly tightened. To include the battery terminal at the starter. Check the AM1 fuse 5amp and AM2 fuse 30amp. Also check for power in and out of the park/neutral switch at transaxle
Thursday, February 25th, 2021 AT 3:46 PM
KHLOW2008
  • 41,814 POSTS
Check and see if the main earth from battery to engine is good.
JUNMAX
If your car has a lot of load ( like power seat, seat memory program, heated seat, almost power to everything) make sure your battery has the hightest CA # reading. If not buy one from dealer. Hope that will work for you.
