2002 Toyota Camry
KCS
  • 2002 TOYOTA CAMRY
Toyota camry- 2002- automatic- 4 cylinder- about 90,000 miles on it. The factory alarm sets off on its own and it doesnt allow me to turn on the car. I've tried resetting it with the key on the driver door, but the key only turns to unlock the doors and doesn't turn back the opposite way (to lock). What causes it to set off the alarm? And how can I fix it? The trick that has worked so far is to turn the key a few times on the door (I lock it while I'm inside the car) then I press the red button (alarm button) on the side and while holding it down I start the engine. That seems to work most of the time. Please Help!
Friday, October 19th, 2007 AT 12:09 PM
2CARPRO JACK
  • 11,533 POSTS
What red alarm button? Is this an aftermarket alarm? If it is, remove it.
Friday, October 19th, 2007 AT 3:24 PM
KCS
Its an alarm button installed into the dashboard right next to the steering wheel on the left side. Most of the time the light is off. But when the alarm goes off it starts blinking.
Friday, October 19th, 2007 AT 3:34 PM
2CARPRO JACK
  • 11,533 POSTS
Is it factory or aftermarket?
Saturday, October 20th, 2007 AT 7:40 AM
KCS
Its the factory alarm. Is what i've been told. I've looked in the manual and it doesn't have any information on that.
Monday, October 22nd, 2007 AT 11:43 AM
2CARPRO JACK
  • 11,533 POSTS
If the door lock doesnt work properly, I would start by fixing that. If it can engage the alarm and disengage it, it wil have to be working properly before the alarm can
Monday, October 22nd, 2007 AT 12:21 PM
KCS
Thanks for your help! I'll give it a try.
Monday, October 22nd, 2007 AT 12:25 PM
