2001 Toyota Camry valve cover gasket
2001 TOYOTA CAMRY
13,397 MILES • 4 CYL • FWD • MANUAL
DREAMAUDI
I bought this car 3 yrs ago. Records showed valve cover replacement at 94,480 miles.At 98,719 miles the gasket was again replaced after a dealer (not the seller) reported oil leaking at the site. They speculated that the replacement had been improperly installed. At the 111,229 mile service, the mechanic again noted a leak at the VC gasket. Because it was under their service warranty, the dealer replaced the part at no charge. A different shop noted the need for a VC gasket at 116, 989. This time I elected not to replace the part. Now at each oil change mechanics note the leak.. I notice a cloud of blus smoke when I start the car after it has sat for 3 days or longer. My question: what could possible cause such frequent failure of the VC gasket? Should I replace it and the oil pan gasket, which also leaks, even though the car does not need oil between change, nor does it leak on the garage floor.
Aug 31, 2009 at 7:42 PM
  • 31,937 POSTS
Hi there,
The valve cover gasket on this car is a thick rubber bead type seal, often they just need re tightening down ( i actually had to do one today) just lift the plug leads and the retaining nuts are there 4 large nuts, as for the sump this has no gasket but is chemically sealed, use only the Toyota black sealant, and apply as per instructions on the tube.
mark (mhpautos)
Aug 31, 2009 at 10:09 PM
