2001 Toyota Camry radiator fluid temperature
MANDHPATI
2001 Toyota Camry
What is the approx radiator fluid temperature
Jul 20, 2009 at 4:19 AM
STEVEW84
  • 673 POSTS
The temperture of coolant you don't want to exceed around 220F. The coolant temp is usually around 212 before the fans kick in and normally puts it around 190 by the time the fan turn off. What problem are you trying to solve?
Jul 20, 2009 at 10:31 AM
