2001 Toyota Camry PO420
BIGBODYCHEVROLET
  • 2001 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 133,000 MILES
First of all its a camry Solara wasn't in the drop down window. Hey I keep getting a PO420. Used to come on about every week. I replaced the rear cat today now it takes about 10 20 miles for the code to come back after I clear it. I torqued the manifold it was ok. I don't hear an exhaust leak anywhere. It has a pre-cat on it. I thought it might be it. Don't really know. Both 02 sensors are reading voltage. Any suggestions would be appreciated.
Tuesday, January 15th, 2008 AT 9:06 PM
BLACKOP555
  • 10,371 POSTS
I would change the pre cat. If that is it your sensor is bad or the pcm is not reading it properly.
Tuesday, January 15th, 2008 AT 9:42 PM
BIGBODYCHEVROLET
Is it possible that the cat I got isn't 50 state emissions? Which my car has. Can I put a header on where the precat used to be without major complcations? Thanks
Tuesday, January 15th, 2008 AT 11:58 PM
