2001 Toyota Camry P0500 Code, already tried to replace VSS
TFURGESON
Electrical problem
2001 Toyota Camry 4 cyl Automatic 30000 miles
My check engine light only turns on when it is hot out. Whenever it is cool out the car has no problems and drives perfectly. Currently the car shifts very erratically and the speedometer does not work correctly or sometimes at all. I have replaced the Vehicle speed sensor and the car worked perfectly for a day then the problem came right back. I also reused the rotating shaft that was on the old VSS. What could be the problem and is there a simple way to check?
Jun 19, 2010 at 3:32 PM
KHLOW2008
  • 41,812 POSTS
Hi tfurgeson,
Thank you for the donation.
I have emailed you the diagnostic files. Hope they are helpful.
Let me know if you require additional help.
Jun 19, 2010 at 11:37 PM
TFURGESON
KHLow2008.
I have tried this out and it seems that the connection at the ECM has the correct voltage going to it, but would this test also prove that the wires from the VSS harness to the ECM are still good or is there another test that can help me decide this?
Jun 20, 2010 at 3:57 PM
KHLOW2008
  • 41,812 POSTS
If the voltage test good, that means the wires going to the PCM are good and no further test are required. However as the problem is intermittent, check connectors for contaminations and looseness as these would cause the problem indicated.
Jun 21, 2010 at 7:19 AM
