2000 Toyota Camry car bushings
GRACERC
  • 2000 TOYOTA CAMRY
  • 4 CYL
  • 155,000 MILES
How often do bushings needs to be replaced? Is that expensive? (Can you give just a ballpark range?) This is our only car, so it is driven frequently. I don't know if weather is also a factor; we live in Baltimore.
Wednesday, December 16th, 2009 AT 6:53 AM
  • 31,937 POSTS
HI there, there are a number of various bushes in you car, suspension front & rear, chassis and sub-frame mountings, engine mountings as well, often they will last for years, but can deteriorate with fluids such as oil & petrol leaking onto them, when worn you may hear knocks or squeaks, and with suspension & steering you may have vibration & tyre wear issues, these should be checked at each service so you can see if some are starting to cause you a problem, they won't fail over night, so with periodic inspections you will have ample time to have them done, as for costs they all vary in price and labour to replace.
Mark (mhpautos)
Wednesday, December 16th, 2009 AT 7:19 AM
GRACERC
Thanks for your quick reply! :-)
Wednesday, December 16th, 2009 AT 1:12 PM
Related General Content
