2000 Toyota Camry Acts Like A Bad Battery
124,000 MILES • 4 CYL • 2WD • AUTOMATIC
BAMSPY
Yesterday, the camry wouldnt crank, like the battery was dead. I jumped it off, and had the battery checked...its good. Removed the starter, had it checked out...slightly low amperage, but not enough to be a problem. Anyone have any idea what it could be? It takes 2 batteries to get it cranked, and when driving you can feel a stall when hitting the brakes, turning on the a/c, or the headlights.
I need some help here...lol
bamspy
Aug 10, 2010 at 5:06 AM
MMPRINCE4000
  • 8,548 POSTS
Check alternator output using a DVOM connected to battery with engine running, output should be 13.5-14.0V.
If OK, I would clean the battery connections and terminals, also make sure the starter mounting area is clean, as starter grounds to block.
Aug 13, 2010 at 2:27 AM
