2000 Toyota Camry
JOHN DENNY
  • 2000 TOYOTA CAMRY
Electrical problem
2000 Toyota Camry 6 cyl Two Wheel Drive Automatic
must I remove the steering wheel to replace the ignition lock cylinder
Tuesday, July 15th, 2008 AT 6:28 PM
BMRFIXIT
  • 19,053 POSTS
No need to remove steering wheel
1. Disconnect negative battery cable.
Remove upper and lower steering column covers (it may be necessary to first remove lower instrument panel trim panel). Remove outer plastic trim cover from lock cylinder assembly (if equipped). 2. Disconnect ignition switch harness connector(s). Remove screw(s) retaining ignition switch to lock cylinder. Remove ignition switch from lock cylinder. To install, reverse removal procedure.
Good luck
jack
Tuesday, July 15th, 2008 AT 8:58 PM
