2000 Toyota Camry
KAKAYAL
  • 2000 TOYOTA CAMRY
2000 Toyota Camry 86000 miles
"Check Engine" Light came ON today. From AutoZone got code as P0136 (Bank 1 Sensor 2) Malfunction. What is the remedy?
Tuesday, February 5th, 2008 AT 9:47 PM
BLACKOP555
  • 10,371 POSTS
Chances are your O2 sensor on bank 1 after the catalytic converter is failing and should be replaced, you can switch it to another one and see if the code follows it if it does replace it, if not you may need a new catalytic converter.
Tuesday, February 5th, 2008 AT 10:01 PM
