2000 Toyota Camry 4 cyl Two Wheel Drive 222222 miles
my window is stuck down and I need to know how to fix it
Tuesday, July 28th, 2009 AT 7:28 PM
F4I_GUY
MECHANIC
Try hitting the center of the door panel while playing with the switch. If it's a faulty window motor sometimes this helps it work for a bit. If that doesn't work you will have to pull the door panel off and test the switch and motor.
