1999 Toyota Camry horn
230,150 MILES • 6 CYL • AWD • AUTOMATIC
ANIYA00
my horn is making no sound when i push it but i know it work cuz when i put it to the battery it goes off.i would just like to know some suggestions cuz i really dont what to do and i have an expired sticker it wont pass inspection.
thank you
Feb 7, 2009 at 3:40 PM
BLUELIGHTNIN6
  • 16,542 POSTS
have you inspected fuses?
Feb 7, 2009 at 6:48 PM
ANIYA00
yeah i inspected all the fuses.i just dont know what else it could be
Feb 8, 2009 at 5:21 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Also need to inspect the horn relay. If that is OK, your horn switch or pad is faulty. check that some damage has not occurred to the steering wheel where the car horn button (usually a very large one) is located. Even a small piece of plastic that sometimes breaks off one part of the steering wheel can lodge in the space between the horn and the main part of the steering wheel. Dislodge this piece of plastic or other debris and you may be able to depress the car horn button and make the horn sound. If all is OK here, there is the possibility that the wire that runs from the horn assembly has been severed.
Thanks for using 2CarPros.com!
Feb 8, 2009 at 5:40 AM
